11 Users Online (9 Members):
Forums >> Community >> Newbies >> Problem with floors
12 Posts No Rating |
Hey, I have a question regarding the floors intersepting walls. In the first picture, you can see that the floor extends perfectly into the wall. But in the second picture, you can see that they are not extending into the wall but overlapping. The first picture is taken from somekind of project. And I would like to know, if they have used a masking region or somekind of other tool to cover the overlapping part? OR anybody have any suggestions how to do it? or how it should be done in revit? I have read lots of threads but I haven't got any help from there. Regards, Tom
Hey Neotropic, You're right. You could mask it in 2D, (image 1 you can see what I had looks just like your's) Now when using REVIT 2010, click modify -> Cut Profile. Now select the inner wall and draw where you'd like to cut the wall (image2), You'll see there is an arrow in the first line you'll draw, make sure it points to the part you want to remain visible. Click finnish (image3) Now you can repeat these steps for the floor (if necessary as in my case) (image 4&5) I hope this was helpful, good luk. Edited on: Tue, Sep 15, 2009 at 3:38:27 AM some how I'm not able to ad the images I hope you'll be able te get there without em.
Edited on: Tue, Sep 15, 2009 at 3:43:13 AM
Before you try what "Gebber" told you, did you try to use the "Join Geometry" tool between the walls and the floor???
good one typhoon, that's way faster
Mass Floors not all showing up - some missing |
Wed, Apr 11, 2012 at 4:44:46 AM
Joining the Geometry of two floors |
Wed, May 14, 2008 at 5:46:12 AM
Attaching stairs to floors |
Wed, May 24, 2006 at 11:29:47 PM
Grouping Floors |
Mon, Aug 22, 2005 at 3:47:49 PM
Massing Question - Extending floors into wall core |
Tue, Mar 4, 2008 at 10:27:59 AM
