Forums >> Revit Systems >> Technical Support >> Floor Drain Primer
Mon, Sep 14, 2009 at 9:49:12 PM | Floor Drain Primer
vinnygolfer
4.5 Stars: 4 Votes
hi all, i'm using MEP 2010 and need to run a 1/2" drain primer from the cw supply. all the floor drains that i can find only have sanitary connectors. is there a way to add a cw connection to the family? or should i just run the cw line close to the drain and end it there?
 thank you in advance.
Try to learn at least one new thing every day
Floor Drain
Wed, Jan 26, 2011 at 11:41:11 AM
Trap Primer Family
Thu, Jan 3, 2013 at 4:50:21 PM
Floor slab slope to drain
Wed, Mar 11, 2009 at 11:04:06 AM
Roof Drains
Thu, Apr 9, 2009 at 3:51:13 PM
Roof Drain Tag that reads area automatically?? is it possible
Sat, Apr 20, 2019 at 9:37:35 AM
Page generation time: 0.2631
