Forums >> Revit Building >> Technical Support >> Roof Ends | Facias + Parapet Tops
Mon, Sep 14, 2009 at 2:08:08 PM | Roof Ends | Facias + Parapet Tops
BCARevit
How do I prevent the ends of walls anf roofs from being white when they are exposed in rederings.  I did wrap all the walls which gave then the exterior material but this is not possible with roofs.  I cant imagine the only methods to to build even details into the model until the white spots go away.
Mon, Sep 14, 2009 at 2:21:14 PM | Roof Ends | Facias + Parapet Tops
tim123
4 Stars: 19 Votes
Use the fascia tool to add fascias.  You can also us the paint tool to overide the edges.
Roof Overhangs, Facias and Soffits
Wed, Sep 23, 2015 at 2:07:38 PM
Roof Joins for crickets on roof
Tue, Jan 12, 2010 at 2:36:02 PM
Roof Parapets - Where to start?
Wed, May 18, 2011 at 4:13:58 PM
Built up roofs?
Fri, Sep 28, 2007 at 3:46:20 PM
Wall cappings
Fri, Sep 1, 2006 at 1:10:18 AM
Page generation time: 1.8590
