29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Beam System Visibility
28 Posts No Rating |
Hello all, Quick question about the beam system I just created. For some reason I can't see it in any view. I've had this happen before with individual members and discovered that the view had to be changed to a higher level of detail, but that doesn't seem to be working here. I looked all through Visiblity Graphics and everything appears to be on and it's on the correct workset... Thanks in advance for any suggestions!!
Are you using phases?
Not currently, and I double checked to see the that view I was using was set to "show all" just incase that was an issue...
Is it possible that it's hidden by other elements, or above the views that you're looking for it? Try and draw another quick one outside the model and see if you can see it. If it disappears, it's probably turned off in VG.
Thanks for the help I'll keep playing with it....
Beam System Visibility |
Wed, Mar 22, 2006 at 9:23:08 AM
structural beam system visibility |
Fri, Jun 27, 2008 at 12:24:51 PM
Beam System Tag |
Fri, Aug 14, 2009 at 3:09:33 AM
Beam system height VS. Beam height error |
Fri, Jan 22, 2016 at 4:31:20 PM
Adding a beam system issue |
Sun, Jun 15, 2014 at 2:58:10 PM
