Forums >> General Discussion >> Revit Project Management >> Can't change contour display properties in 2010
Mon, Sep 14, 2009 at 8:39:33 AM | Can't change contour display properties in 2010
JST000
JST000 Avatar
I used to make my secondary contours grey and dashed and my primary contours solid and thick, by going into Object styles to change them globally. But it doesn't seem to work anymore in revit 2010.  I even tried to override it in the view as well with no luck. However. when i delete the topo and undo, when it reappears it's got the right display properties, until I zoom in or out. Anyone know what's going on?
Mon, Sep 14, 2009 at 8:47:03 AM | Can't change contour display properties in 2010
JST000
JST000 Avatar
I figured it out.....My contours were set to existing in phasing properties.
Change multiple sheets' properties at once [ 1 2 ]
Sat, Nov 1, 2014 at 8:50:25 AM
17
Display properties of glass in existing windows?
Thu, Jul 27, 2006 at 10:16:59 AM
Hide 'Contour' Lines in Modified Sub Element
Tue, Dec 3, 2013 at 9:21:03 AM
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:52 PM
Contour intervals
Thu, Apr 9, 2009 at 7:46:15 AM
Page generation time: 1.7952
