Forums >> Revit Building >> Technical Support >> Window Family issues
Fri, Sep 11, 2009 at 11:17:31 AM | Window Family issues
Fukudome
1 Stars: 1 Votes
I have created a window fmaily that I am unable to place into a wall. When i try to place it, it gives me the "cannot make" error.  I am attaching the revit family to this post for ref.
 Any ideas what I am or am not doing correctly here?  I thought I had the opening created correctly?
Fri, Sep 11, 2009 at 12:17:12 PM | Window Family issues
tim123
4 Stars: 19 Votes
Make the wall thickness in the family the same as the one in the project that you're trying to host it to.  This will reveal the constraints that are stopping it from being hosted.
Mon, Sep 14, 2009 at 5:09:52 PM | Window Family issues
Bronsart
This is a problem I ran into a lot when I was creating my own wall hosted families.  When you make a solid or void, it seems to be relative to the CENTER of the wall... not the face.  Always make sure your objects are hosted or locked to the appropriate part of the wall.  When making a wall hosted family, right click on the wall and create a new "wall 2" with a different thickness.  I'll periodically change between the two walls to make sure my family is working correctly.
SECTION CUT VISIBILITY ISSUES WITH WINDOWS
Wed, Feb 3, 2016 at 11:28:10 AM
How to build a butt joint corner window family?
Thu, Mar 27, 2008 at 12:21:14 PM
Window Family Issues
Tue, Sep 4, 2007 at 6:50:24 AM
Window Issues
Sat, Jun 13, 2009 at 10:10:56 AM
window flip issues
Mon, Apr 3, 2006 at 2:21:09 AM
Page generation time: 4.7265
