Forums >> Revit Building >> Technical Support >> Orient By plan
Fri, Sep 11, 2009 at 3:44:48 AM | Orient By plan
nirim
5 Stars: 12 Votes
Hi there
As someone know the 2010 command for the 2009 View – Orient – By plane command?
nirim
Fri, Sep 11, 2009 at 12:50:42 PM | Orient By plan
tim123
4 Stars: 19 Votes
Right click on the view cube.  If you have it switched off, you can switch on by clicking on 'User interface' on the view menu.  You can create a shortcut to do that if you prefer the view cube switched off.
Orient - by plane is on the little down arrow on the steering wheel.
Edited on: Fri, Sep 11, 2009 at 1:09:04 PM
Mon, Sep 14, 2009 at 2:56:06 AM | Orient By plan
nirim
5 Stars: 12 Votes
 tim123
  Many thanks.
nirim
Orient section cut to object
Sun, Jan 31, 2010 at 8:28:59 AM
Orient a view perpendicular to a work plane
Thu, Dec 17, 2009 at 11:52:39 PM
Orienting plan regions
Thu, Sep 3, 2015 at 2:59:30 PM
2D Axonometric
Mon, May 17, 2010 at 11:54:18 AM
Orient a light to an angle Mass Plane in Revit 2010
Tue, Nov 24, 2009 at 10:32:25 AM
Page generation time: 0.3366
