20 Users Online (18 Members):
Forums >> Revit Systems >> Technical Support >> Door Trim Parameters
4 Posts No Rating |
Is it a general practice to add door trim to a door family? I used the solid sweep command to create a wall based door trim. When I use an existing profile I can't get it to change sizes, so it very limited. I can sketch a simple block as trim and resize it easily, but it doesn't look good. Also, when I have a stacked wall (stone wainscot, plaster above) the door doesn't cut right. The door will host to the plaster, but the trim falls behind the stone wainscot. If I change the host to the stone, then the door jamb sticks out past the plaster. Help?!? I've attached a screen shot of the exterior elevation.
Wall Finishes Aligned to Door Trim |
Thu, Jan 21, 2016 at 4:08:48 PM
Door parameters not scheduling or tagging in double door. |
Mon, Sep 26, 2011 at 3:29:50 PM
Edit/Add trim to Door Family |
Thu, Jan 14, 2016 at 10:02:29 AM
door trim stops short of floor |
Wed, Jul 24, 2013 at 3:24:32 PM
Specialty Door(s) - Help Needed! - Transom, Trim, etc. |
Mon, Jun 4, 2012 at 4:44:07 PM
