Forums >> Revit Building >> Technical Support >> Break the Level Line
Thu, Sep 10, 2009 at 1:13:57 PM | Break the Level Line
dropem
dropem Avatar
is it possible to break the level line in elevation so you can have the tag on both sides but not have the line run all the way across the elevation?
Mon, Dec 5, 2011 at 8:32:12 AM | Break the Level Line
AlphaOjo
*bump
Has this issue still not been resolved as of Revit 2012?  It would really help clean up my drawings if I could break the level lines like I can with the grid lines...
Mon, Dec 5, 2011 at 9:08:24 AM | Break the Level Line
You can't do this and I don't believe I have ever seen it on the wish list.  If you consider it to be an issue, please place it on the official wish list on the AUGI site.
Mon, Dec 5, 2011 at 4:33:06 PM | Break the Level Line
aspect
5 Stars: 2 Votes
Think of the poor builder on site.
I would say if you need a marker/tag on both ends of your level line, then either A. the level line is too long on the sheet in which case you should leave the line fully intact so the builder doesnt need to find a long enough ruler and work out by eye what elements are on that line, or B. The level line needs to be that long because the elevation is long - in which case you should leave the line fully intact and have markers/tags on both ends - again, to help the builder on site.
If you feel the level lines clutter your drawing, maybe a change in line type, thickness and/or colour will help to differentiate it?
www.aspectarch.com
Mon, Dec 5, 2011 at 4:39:08 PM | Break the Level Line
AlphaOjo
Thanks for the tips.  I was just hoping for a cleaner design document drawing, but I guess it makes more sense to just leave them intact.
Stair break line problem
Fri, Jul 17, 2020 at 4:21:45 PM
Break Line & Weld sybol families
Wed, Apr 28, 2010 at 9:18:41 PM
Stair Break Line Customization
Mon, Dec 12, 2011 at 4:20:09 AM
Showing break lines with Ramps and Stairs
Mon, Jul 30, 2018 at 11:02:36 AM
Break line in elevation
Sun, Nov 23, 2008 at 4:19:24 PM
Page generation time: 2.6091
