Forums >> Revit Structure >> Technical Support >> Revit not placing gaps
Wed, Sep 9, 2009 at 10:06:26 AM | Revit not placing gaps
sblanck
Greetings
I imported a RAM model and none of the steel joists will allow for the gap you see in plan. The engineer likes to see this gap.  I have checked all the settings and defaults between this project and others.  The others show the gap between beam and joist and when I add more beams and joists the gaps automaticaly appear.  In this other project they do not appear so I had to manually drag all the joists back to show the gap.  Not sure where else to look or if this has something to do with the RAM model itself.  I also copied a portion of these items to a project that was working with showing of gaps and no change for those members.  Life would beasier if I didnt have to manually go and grabe each joist and drag it back.  Any ideas?
S
Gaps is walls and corner [ 1 2 ]
Thu, Jan 12, 2017 at 12:19:52 PM
15
Material Image Gaps
Wed, Jul 6, 2016 at 12:57:26 PM
Foundation Wall Gaps @ Doors
Wed, Jun 11, 2008 at 4:47:52 PM
How to make Panels overlap Mullions & how to add gaps between those panels???
Sun, May 18, 2014 at 11:12:35 AM
Gaps between Subregions
Tue, Sep 23, 2014 at 11:08:36 AM
Page generation time: 5.9172
