Forums >> Revit Building >> Technical Support >> Multiple Updates of Revision by sheet at once - RAC 2010
Tue, Sep 8, 2009 at 2:01:23 PM | Multiple Updates of Revision by sheet at once - RAC 2010
twhisker
2.5 Stars: 5 Votes
Autodesk got it partially right.  The revision schedule used to have the option of showing on all sheets or just where a revision occurs.  This should have been a choice per revision and not for all.  Now they offer the option of manually adding a revision to a sheet name even if there is no revision cloud on that sheet.
The way we use this, is that the first 5 or 6 revisions issued during the design process - schematic, develeopment, CD, permit, bid, etc......  These show up on every sheet.  Then the ASI, RFI revisions follow - these only show up on the sheet in which revision appears.
With 2010, you can manually add revisions to sheet.  Go into a sheets properties and Edit Revisions on Sheet under Identity Data.  There click on the check box of the revisions you want to appear on that sheet.  It's a great work around, BUT you have to go into every sheet and so this individually.  Thats fine if its an addition to a garage, but what if its Freedom Tower?!  I tried selecting all sheets at once and then edit properties, but revisions on Sheet is the ONE parameter that doesnt show up on a multiple edit.  I assume this would require a macro to be built - I guess this is a good time to start learning how to write them.  It would be BETTER to have the option to show on every sheet by revision in Sheet/Issue Revisions.
Does anyone have a macro to so this?  A macro to study for a different task? A good source for learning macros and API?  Thanks!
Revit Architecture 2010
Tue, Sep 8, 2009 at 3:38:27 PM | Multiple Updates of Revision by sheet at once - RAC 2010
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I can't say i've done or needed that ability but, off the top of my head.  I've always just placed a cloud on each sheet that needed a particular revision.  I just put it on one, then copy to clipboard, then paste  -->selected views and select all the sheets that need to be issued with that revision...'
Done.
Regards,
Chris.
Fri, Sep 11, 2009 at 11:36:26 AM | Multiple Updates of Revision by sheet at once - RAC 2010
twhisker
2.5 Stars: 5 Votes
Thanks.  We were creating "dummy" clouds before to activate the revisions.  But we still had to edit them to be invisible.  I hate workarounds!!  We use the revisions log to show all issuances of a set up until construction.  Then we only mark sheets that have changes on them.  Oh well back to the wish list - as always - thanks for your help Mr Spot!
Mon, Dec 21, 2009 at 3:15:29 PM | Multiple Updates of Revision by sheet at once - RAC 2010
ollienz
ollienz Avatar
Yeah I am after the same thing as you, twhisker. cloudless global revisions
The idea I had is to manually edit your titleblock family and place a line of 'dumb' text next to your 'smart' revision schedule, which would have the revision info for this global issue. what do you think?
Sun, Jan 5, 2014 at 3:33:14 PM | Multiple Updates of Revision by sheet at once - RAC 2010
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
With Revit 2014 this is now possible through the API.  There is a tool to quickly "UpRev" many sheets in one quick operation in just a few seconds.
Download the free tool here:
http://www.xrev.com.au/products/Xrev-Freebies
Regards,
Chris.
Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
Mon, Aug 29, 2011 at 7:58:12 AM
RAC 2010 - Revision Block Disappears on Rev. 2
Thu, Jul 8, 2010 at 11:16:36 AM
Hiding a Revision in the Revision Schedule
Thu, Nov 21, 2013 at 3:04:51 PM
sheet issue / revision Schedule spacing & line spacing problem
Mon, Jun 16, 2014 at 7:00:04 PM
REVISION TAG AND SCHEDULE
Sun, Jul 20, 2014 at 3:09:52 AM
Page generation time: 0.7007
