Forums >> Revit Building >> Technical Support >> Problems with Stacked walls
Tue, Sep 8, 2009 at 8:28:37 AM | Problems with Stacked walls
MARS1276
1 Stars: 1 Votes
How many of you actually use stacked walls?
I have found them to be problematic when trying to place Keynote text in a section detail.
Also have found them to be tricky when it comes to foundation footers because it treats the wall as an architectural wall and not a structural wall.
Anybody else have problems that I should be aware of or any solutions?
Tue, Sep 8, 2009 at 8:38:24 AM | Problems with Stacked walls
I find stacked walls usefule for initial placement but after that they can cause other problems.  That is when I like to right click on them and select "breakup" to turn them back into stacked... single walls.
Tue, Sep 8, 2009 at 9:58:07 AM | Problems with Stacked walls
MARS1276
1 Stars: 1 Votes
I didn't realize it would be that simple to change the wall back to it's original type.  So basically I could draw walls using stacked walls, and then choose "breakup" when it comes time to detail a section?  Awesome!
What were some of the other problems you faced when using stacked walls?  I haven't worked with it much so I am not sure what to expect.
Mon, Dec 21, 2009 at 3:01:20 PM | Problems with Stacked walls
MARS1276
1 Stars: 1 Votes
OK, I now have some experience with drawing stacked walls!  I did encounter a problem however.  When I used the 'draw wall by face' tool (somewhere under 'Massing and Site' tab) it would draw fine if you did the 'chain-select' option.  But even then, every time I 'break up' a stacked wall, the upper part of the wall "flips" on itself and you now have the inside of the wall facing the outside; totally off of the wall beneath it as well!  So this can be fixed easily enough by going to plan view and selecting the "flip" arrows next to the wall.  What I want to know is, how can this issue be resoved WITHOUT having to do that extra step?
2016 Stacked wall problems
Tue, Apr 5, 2016 at 12:03:48 PM
2013 - Stacked wall problems
Thu, Dec 12, 2013 at 8:23:39 PM
stacked walls
Mon, Sep 10, 2018 at 9:55:14 AM
stacked walls
Tue, Nov 25, 2014 at 5:51:10 PM
Stacked Wall Problems
Wed, May 18, 2016 at 9:10:52 AM
Page generation time: 0.4200
