Forums >> General Discussion >> Revit Project Management >> 3D capabilities
Tue, Sep 8, 2009 at 7:57:05 AM | 3D capabilities
MARS1276
1 Stars: 1 Votes
How many actually use Revit for it's 3D capabilities.
I work for a construction/engineering company that mostly do steel fab'd warehouses.  Our plans are almost entirely 2D plans.
We made the switch from AutoCAD 3.0 with Architectural Desktop 3.3 (yup, they used that software until about a year ago; and we still use it sometimes) because of it's capability to easily show elevation views and capabilities to automatically update in other views and mainly for the sake of keynoting.
While I am impressed with it's capabilities, I have found it's use for our needs to be impractical.  So I was wondering, do other companies that use this program do mostly 2D drawings; and if so, how/why do they find it to be better than AutoCAD?
Some reasons I have found for it being less practical than AutoCAD are as follows:
Cons:
Takes longer than CAD to produce sheet drawings.
Takes longer than CAD to produce section detail drawings; with cad we can simply copy/paste details into a job that have the same wall-type as another project.  There are ways to tailor this aspect to make it quicker, but so far I have yet to convince my Drafting Supervisor that this would be a quicker and more efficient (better) way to go about our (creating detail drawings) of our wall sections.
Have found that while dimensioning for the most part is better than CAD, still have some of the same technical issues as dimensioning in CAD.  Kind of a trade off of pros and cons I think that really make it not much better than dimensioning in CAD.
Updating walls can have an adverse effect on other sheets we work with.
Long loading time.
Still have to manage each view/sheet just like in CAD to show only what you want to see on the print.
Pros:
Easily generates Elevation views
All sheets within one file
Sat, Sep 12, 2009 at 6:45:58 AM | MARS1276
b8dnbbr
Quoting MARS1276 from 2009-09-08 07:57:05
Cons:
Takes longer than CAD to produce section detail drawings; with cad we can simply copy/paste details into a job that have the same wall-type as another project.  There are ways to tailor this aspect to make it quicker, but so far I have yet to convince my Drafting Supervisor that this would be a quicker and more efficient (better) way to go about our (creating detail drawings) of our wall sections."
 somewhere i saw a (3 part?) blog that showed a few ways to deal with 2d details. i think two methods were importing dwg.
 "Have found that while dimensioning for the most part is better than CAD, still have some of the same technical issues as dimensioning in CAD.  Kind of a trade off of pros and cons I think that really make it not much better than dimensioning in CAD.
Long loading time.
Pros:
have you considered using revit as just a sheet manager? :-)
really, autocad seems incapable of printing the last few years. it seemed to work ok back in 2002. not sure where they went bad.
i'm using only as a student, so presumably there are workarounds I haven't discovered.
Edited on: Sat, Sep 12, 2009 at 6:49:47 AM
Edited on: Sat, Sep 12, 2009 at 6:50:29 AM
Mon, Sep 28, 2009 at 9:04:18 AM | 3D capabilities
MARS1276
1 Stars: 1 Votes
I do not understand how using Revit as a Sheet Manager would be effective?  My work wants to get as much use out of it as possible.  It is, afterall, a very expensive program just to be used as a sheet manager.
Question - Revit Architecture-Schedule Alerts & Capabilities.
Wed, Jul 11, 2012 at 5:32:07 PM
Capabilities to isolate phases
Tue, Nov 28, 2006 at 5:43:02 AM
Revit's capabilities
Tue, May 14, 2013 at 8:07:08 PM
Photo quality renderings
Thu, Dec 21, 2006 at 4:27:32 PM
SketchUp v Revit v formZ
Thu, Jul 27, 2006 at 10:55:49 PM
Page generation time: 0.0175
