Forums >> Revit Building >> Technical Support >> Three point curve
Mon, Sep 7, 2009 at 8:20:00 PM | Three point curve
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
RAC 2010
i'm trying to put a curve on top of this rectangle..
but it only wants to snap to a half circle with a radius
of 3' 2"--- i want the top of the curve to be 3' at the top
of that center line.. if i type in a different radius i get
an error.. i can stop it at several positions below the
top of that line- but i can't change the radius number
or make the top of the curve snap to the top of that
center line..
Tue, Sep 8, 2009 at 1:15:51 AM | Three point curve
tim123
4 Stars: 19 Votes
Draw a ref plane at the where you want the top of the curve.  It will snap to that.
Tue, Sep 8, 2009 at 1:28:43 AM | Three point curve
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
see the image- it only snaps to a half circle- it won't
snap to a reference plane..
Tue, Sep 8, 2009 at 1:39:13 AM | Three point curve
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
has anyone ever attempted to admit that revit
is too hard to understand for 99.9% of all the
people who ever tried to learn it?
Tue, Sep 8, 2009 at 7:33:00 AM | Three point curve
tim123
4 Stars: 19 Votes
Draw a vertical ref plane on the centreline and use snap overides to snap to the intersection (type SI).
Although a flattering thought, I don't believe that I am in the top 0.1% of people that have tried to learn Revit.  I found that using the help and having a 'can do' attitude helps to learn the software quite quiclkly.  I know that I still have more to learn, but I am pleased with my progress so far.
Tue, Sep 8, 2009 at 7:52:55 AM | Three point curve
Simple ... use a three point arc and on your options bar, select radius and enter the 3' dimension.  Now pick your line ends.
You have to pay attention to those darn options !
Tue, Sep 8, 2009 at 8:07:35 AM | Three point curve
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
yes tim thanks- i'm just a slow learner.. some people are
pretty good at leaning revit..
that would be nice if i could type SI but autodesk
don't let us have any shortcut keys unless we
use the ribbon and i cannot use that..
we also don't get any model lines- but that's not
too bad..
i feel very very lucky i can use revit at all- and if
the standard interface doesn't work for 2011 then i'll
be forced to stay with 2010 forever- and that's not something
i've ever been inclined to do.. i started with revit version 8.
i know the ribbon very very well and it requires me to follow
workflows- and i can never do that.. and the QAT is a very poor
solution for me too..
i've posted comments at the autodesk discussion forum about
the ribbon- but i only made comments about little things that
needed to be fix and have always said i didn't think the ribbon
was fundamentally wrong- because i know many people think
like the ribbon.. but i will continue to push for the standard UI
as and option that gets supported and updated.. i'm very clear
on that now..
orthogonal dimensions to radial dimension center point
Fri, May 14, 2010 at 3:22:32 PM
Reference Points that have Normalized Curve Parameter
Tue, Jun 3, 2014 at 4:15:14 PM
Logo Placement in Curve Shapes
Wed, May 2, 2012 at 9:08:20 PM
Curve Walls
Mon, Dec 22, 2008 at 6:13:27 PM
Making Curve Ladder Trusses
Tue, Jan 16, 2018 at 8:21:53 AM
Page generation time: 1.1934
