Forums >> Revit Building >> Technical Support >> stair with 2 winder -> railing
Mon, Sep 7, 2009 at 3:57:30 AM | stair with 2 winder -> railing
Kuiper
I have a problem with the railing of the stairs with two winder.. As you can see on the drawing, the first baluster isn't going as it supposed to as well the stringers. Does anyone have a solution for this problem?
Wed, Sep 9, 2009 at 12:38:00 PM | stair with 2 winder -> railing
Every point where a stringer or a railing has to change direction vertically or horizontally, the sketch line has to be broken.  Because of the winders, the railing and stringers change direction vertically (they increase in slope angle).  You need to break these sketch lines appropriately.
Winder Stairs in 2013
Tue, May 8, 2012 at 12:49:31 PM
How to achieve newell posts on winder stair
Tue, Jul 24, 2007 at 6:18:30 AM
Add railing to existing stair
Tue, Oct 29, 2013 at 7:49:39 PM
Railing at stair bottom!
Thu, Feb 28, 2008 at 10:57:33 AM
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:22 PM
Page generation time: 0.5957
