Forums >> Revit Structure >> Technical Support >> Can't delete infilling element without deleting its insert or host.
Sun, Sep 6, 2009 at 2:34:01 PM | Can't delete infilling element without deleting its insert or host.
wil9000
Hi,
Ihave created a new door in 2009, i load it into my project i place it into a wall, all is fine, then when i look at it, the wall is still showing through the door, i highlight the wall in the section of the door to delete it and it comes up with the above error? its happend twice now on same project and i will have a lot more doors to do?
anyone know where i am going wrong?
jpeg attached below for example
any guidance be gratefully recieved
Thanks
WIll
Tue, Sep 8, 2009 at 12:16:36 PM | Can't delete infilling element without deleting its insert or host.
Your problem may be your view range.  You are actually seeing the edges of the wall below.  Change your view depth if you don't want to see this or edit your floor to come into the door opening.
Tue, Sep 8, 2009 at 3:19:53 PM | Can't delete infilling element without deleting its insert or host.
wil9000
Hi,
Thanks for yur reply, I have worked out that it is not my view range, its actually the phasing, everytime i generate a new view be it section or 3D etc, i have to phase it as None and Existing, it seems that under "show all" it is showing the door and the wall - (I hope you understand what i mean) a real pain, I have tried to overhaul the phasing on the whole project as None/xisting but any new sheets i have to change again :-(
Any guiance be gratefully recieved
Tue, Sep 8, 2009 at 3:29:45 PM | Can't delete infilling element without deleting its insert or host.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the properties of each view, there is a field when you can select the default view template.  Create a view template with the phase set to existing then apply it as the default template to you various view templates.  That way, each new view that is created will be automatically phased existing...
Regards,
Chris.
can't delete sweep
Wed, Jun 25, 2008 at 3:25:04 PM
Deleting an element within 3D environment doesn't delete the element from the 2D
Tue, Jun 26, 2012 at 1:35:59 PM
VOID form will NOT work!
Mon, Jan 30, 2012 at 11:11:19 AM
Infilling elements containing sweeps
Wed, Mar 18, 2009 at 3:59:35 PM
Infilling element replaced by a later phase insert must be the same type as the
Thu, Jan 31, 2013 at 2:37:52 PM
Page generation time: 0.9204
