Forums >> Revit Systems >> Technical Support >> compressing revit file
Fri, Sep 4, 2009 at 7:31:13 AM | compressing revit file
mlagunzad
hi outthere, anyone,how do i compress revit file aside from isolating and grouping elements. ?
thanks
Fri, Sep 4, 2009 at 7:50:13 AM | compressing revit file
There is a compress function and audit in your file management.  If you mean other than that, grouping is not necessarily a good thing.  Be careful with that.  You can purge the file of un-wanted families but also be careful with that.  Removing views that are not used will also reduce the size.
And finally... be very careful in using CAD imports - in both the project and families.  There are some good threads here on that subject and AutoDESK U has a good writeup on managing CAD imports.
Thu, Sep 10, 2009 at 8:46:55 AM | compressing revit file
mlagunzad
ok, thank you wwhub
Walkthrough rendering stops
Mon, Feb 22, 2010 at 4:30:51 AM
12
Linked Revit Topography file displayed in hidden lines in 3d view main bld file
Sat, Jul 7, 2012 at 3:38:16 PM
Scheduling from linked Revit file
Tue, Mar 27, 2012 at 7:39:28 AM
Need HELP!! Geting a Navisworks file inn to Revit Structure
Mon, Apr 8, 2013 at 8:02:00 AM
STAIRS IN LINKED FILE WON'T SHOW UP IN MAIN CENTRAL FILE 3D
Mon, Jun 25, 2012 at 3:58:52 PM
Page generation time: 3.6400
