Forums >> Revit Building >> Technical Support >> GUTTER PROFILE not appearing in sections?
Fri, Sep 4, 2009 at 1:48:41 AM | GUTTER PROFILE not appearing in sections?
dnicholson
Hi guys, using 2010.  Created a profile which shows Csection, flashing and gutter.  and using it as a gutter family.  it works fine it appears in 3D and elevations but on my section views that cut through it i cant see it.   I need it there and details?
Thanks.
Fri, Sep 4, 2009 at 2:20:57 AM | GUTTER PROFILE not appearing in sections?
Shanthi
Hi,
2 possibilities.
1. Same material which got merged with the same.
2.Check with fine mode.
Fri, Sep 4, 2009 at 3:21:30 AM | GUTTER PROFILE not appearing in sections?
dnicholson
i changed the material and its still not showing.
I am in fine view, its not appearing in coarse or medium either. It does appear in all those settings on my elevations.
That will Teach me for trying to be clever and save time instead of drawing it on every section and detail!?
Fri, Sep 4, 2009 at 8:32:09 AM | GUTTER PROFILE not appearing in sections?
4 Stars: 205 Votes
Did you create that profile family with "invisibles Lines" or what?
Fri, Sep 4, 2009 at 12:30:28 PM | GUTTER PROFILE not appearing in sections?
tim123
4 Stars: 19 Votes
There is no reason why it should not display.  It  could be a number of things - have you checked the following:
Turned off in VG
Hidden in view
In a workset that is turned off in the view
In a design option that is turned off
In a different phase
Fri, Sep 4, 2009 at 3:56:14 PM | GUTTER PROFILE not appearing in sections?
MARS1276
1 Stars: 1 Votes
Are you using this profile as a wall sweep?  If so check to see if it has 'cuttable' checked.
Sun, Sep 6, 2009 at 9:12:20 PM | GUTTER PROFILE not appearing in sections?
dnicholson
AHA it was the Phasing!!!
always simple when you find out hey.   Thanks all.
CUSTOM GUTTER PROFILE
Wed, Mar 27, 2013 at 1:59:53 PM
Gutter display on roof plan
Mon, Jun 11, 2007 at 3:47:21 PM
Anyone got an easy way to cap the end of a gutter sweep? Anyone?
Wed, Feb 14, 2007 at 7:22:46 PM
Sections tag
Mon, Apr 6, 2015 at 9:50:58 AM
Gutter but what about gutter downpipe?
Mon, Feb 22, 2016 at 12:31:57 AM
Page generation time: 1.9769
