Forums >> General Discussion >> Wishlist >> Exporting revit models to consultants
Thu, Sep 3, 2009 at 11:04:43 AM | Exporting revit models to consultants
Casparos
Probably not even a new item, but:
I cannot provide my consultants [some of them are architects aswell] with all my thoroughly fully paramtric and highly defined families where I worked on for severall years.
So is there a way to export the model, or "publish" the model where all parameters of the families ["selected", walls,windows,doors] are frozen? Lets, say to make the model dumb, and not instantly transferable in other projects!!Actually not only the families but even the system families, because this is the "office standard", so titleblocks, templates etc should be locked. Even the text-styles/dimension-styles and very important the lines styles/line weights and the visibility graphics settings should be locked.
I think the issue is clear,
Cee
(you can start instantly an new firm while receiving one full revit model]
Limit Revit Access to certain consultants within Collaboration for Revit
Fri, Jun 1, 2018 at 2:50:05 PM
Exporting Solid Models from Revit to AutoCAD
Mon, May 23, 2011 at 12:58:48 PM
Coordinating with consultants
Tue, Jan 18, 2011 at 1:43:06 PM
Trouble w/ exporting to AutoCad
Thu, Jan 20, 2011 at 11:18:07 AM
Working with Consultants
Tue, Sep 28, 2010 at 9:29:57 PM
Page generation time: 2.6135
