Forums >> Revit Building >> Technical Support >> Joining Walls
Thu, Sep 3, 2009 at 12:46:01 AM | Joining Walls
blimp
1 Stars: 1 Votes
How do I join these 2 walls?
Thu, Sep 3, 2009 at 12:56:41 AM | Joining Walls
rudyard
1 Stars: 1 Votes
Im not sure  if you have tried it but have you tried the 'join geometry' tool?
If the geometry lines up and has the exact same material it will remove the join line you speak of.....the walls dont literally join, they are still seperately editable but the join lines disapear.
Thu, Sep 3, 2009 at 3:41:57 AM | Joining Walls
blimp
1 Stars: 1 Votes
Rudyard, not sure if this makes sense!
I selected the Join Geometry tool, proceeded to select my FIRST solid geometry (being the brick veneer) then it asks to select the SECOND solid geometry (being my single brick with the return) however when I try selecting the single brick wall, it won’t let me select it.
Any ideas why...?
Thu, Sep 3, 2009 at 3:46:02 AM | Joining Walls
blimp
1 Stars: 1 Votes
To better understand I've attached an image.
Thu, Sep 3, 2009 at 3:54:34 AM | Joining Walls
4 Stars: 205 Votes
Do you have the same "material" in the 2 walls?? What i'm trying to tell you is, the "Material" must have the SAME NAME, you can have in the "Settings>Materials" 2 or more "names" with the same material but to join the walls like you want you must have in the 2 walls the SAME NAME to that material, did you understand???
Thu, Sep 3, 2009 at 4:00:53 AM | Joining Walls
blimp
1 Stars: 1 Votes
Typhoon,
That’s exactly what my problem was. The extended wall was a different material type to the brick veneer.
Now that I have that sorted, how do I remove the RED line I’ve circled?
Thu, Sep 3, 2009 at 4:53:08 AM | Joining Walls
4 Stars: 205 Votes
Use the "Linework" tool, choose "Invisible lines" and pick in that line once or twice until disapear....
By the way, "Welcome to Revit World"....
Edited on: Thu, Sep 3, 2009 at 4:54:34 AM
Thu, Sep 3, 2009 at 6:47:00 AM | Joining Walls
blimp
1 Stars: 1 Votes
Hi Typhoon,
Thank you for your welcome.
I'm very new to REVIT, in fact I have only a whole 6 hours experience on it LOL....
I'm studying Architectural Technology and am in my first year/second semester. In our first semester we used AutoCAD but have now been told that we will only be using REVIT from here on.
The project I'm working on is an assignment for school. It's a split level house, part brick veneer part double brick.
Please don't throw sticks and stones, but spending the little time I have with REVIT it almost feels like a challenge drawing this over AutoCAD.
If for arguments sake I was only going to draw a floor plan for this assignment, would I be better off using AutoCAD? or would I best try drawing it in REVIT using the drawing tools?
Any advice would be great help.
Thu, Sep 3, 2009 at 7:21:17 AM | Joining Walls
tim123
4 Stars: 19 Votes
If I were only drawing floor plans I would use Revit over AutoCAD anytime, it's still faster.  6 hours is not mauch experience in Revit, but keep at it - it gets easier, although there is a lot of functionality to learn.
Thu, Sep 3, 2009 at 7:47:01 AM | Joining Walls
blimp
1 Stars: 1 Votes
Hi tim123,
I agree... I know I'll end up loving REVIT once I get my head around it.
Would you know of any video tutorials for beginners on REVIT?
Thu, Sep 3, 2009 at 8:42:52 PM | Joining Walls
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi blimp and welcome to this world....you can find some video tutorials here:
http://designreform.net/category/tutorials/revit-tutorials/
http://www.youtube.com/user/ddufon#play/uploads/34/HRTlpXBcYpI
http://therevitkid.blogspot.com/
http://revittotd.com/
 http://www.cadclips.com/FreeCADclips.htm
Good luck....
Fri, Sep 4, 2009 at 1:26:47 AM | Joining Walls
tim123
4 Stars: 19 Votes
There are some good basic tutorials on Revit Zone
http://www.revitzone.com/index.php
Fri, Sep 4, 2009 at 10:33:16 AM | Joining Walls
#13
nafenn
sounds the same as the course i did. where are you studying??
Mon, Sep 7, 2009 at 5:39:43 PM | Joining Walls
#14
blimp
1 Stars: 1 Votes
St George TAFE Sydney Australia.
highrise towers slabs-walls joining
Tue, Jun 1, 2004 at 6:18:09 PM
Joining Walls at Awkward Angles
Tue, Mar 11, 2014 at 8:31:13 AM
Keeping walls from snapping
Fri, Jul 21, 2006 at 12:06:03 PM
problem joining walls and structural columns in Revit 2009
Tue, Mar 16, 2010 at 6:27:19 PM
a few issues i need help with (drainpipes, joining walls)
Mon, Aug 24, 2009 at 1:45:19 PM
Page generation time: 1.7213
