Forums >> Revit Building >> Technical Support >> Scale: As indicated
Fri, Aug 12, 2005 at 11:53:50 AM | Scale: As indicated
eepa
5 Stars: 2 Votes
Is there any way to change the 'As indicated' text that appears when we have items with different scales in the same sheet? The point is that I'm in Spain, and I cannot present a sheet with this text in english and I would like to change it for mine own. Thanks in advance.
Mon, Aug 15, 2005 at 5:52:05 PM | RE: Scale: As indicated
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, i don't believe you can. Might be best to check with autodesk support as i'd imagine they should be a language pack of some sort.
Scale bar on sheet onto to display at certain scale
Wed, May 22, 2013 at 12:15:22 AM
scale image
Fri, May 13, 2016 at 1:11:44 PM
Scale Bar Link To Titlesheet Scale.
Thu, May 23, 2013 at 6:36:16 PM
scale check
Tue, Oct 23, 2012 at 5:05:08 AM
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:38 AM
Page generation time: 2.8272
