10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Adding New Section of Roof to Extension On House
78 Posts No Rating |
Hi guys, back again with another question. I am using Revit 2010 Slowly but surely, I am getting closer to the finish line with my model. I have added a side extension onto a 3 bed semi detached house and I just want to make sure that I am getting the roof aspect to it right. When adding the new section of roof, I have just edited the roof footprint to accommodate the new area of roof that needs to be covered. Images attached below. Is this the correct procedure or should I be creating a new roof footprint for the new roof extension and then somehow joining the new roof to the old? May seem a little obvious to many of you guys but I just want to make sure that I am doing things the right way. Does my roof look OK to you? Thanks ever so much Kirk
Edited on: Wed, Sep 2, 2009 at 3:31:19 AM
----------------------------------- USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes. |
You can just edit the roof to show what you want, but the traditional method would be to use the Phasing in Revit. The existing roof would be in the existing phase and then a separate section of new roof in the 'New contruction' phase. In that way you can show existing and proposed views of the building.
How i can repair my house roof? |
Fri, Sep 14, 2012 at 4:52:36 AM
workflow for architectural building section showing roof trusses. |
Wed, Jan 10, 2018 at 10:12:23 AM
Revit Roof+rafting extension |
Tue, Apr 8, 2014 at 3:46:48 PM
Adding a Portico to a Roof [ 1 2 ] |
Sun, Aug 17, 2014 at 3:39:03 AM
16
Can't figure how to make this roof |
Mon, May 18, 2015 at 7:55:11 AM
13
