Forums >> Revit Systems >> Technical Support >> Inserting Fittings on 3d Views
Tue, Sep 1, 2009 at 4:04:38 PM | Inserting Fittings on 3d Views
jrobison
4.5 Stars: 2 Votes
Does anyone know an easy way to insert a fitting on a horizontal pipe in a 3d view?  Everytime I try, it seems like it will not associate it with the pipe and when I rotate the view, it's off in never-never land.  I can easily put a fitting on a vertical pipe, just not a horizontal.
 Thanks
Wed, Sep 2, 2009 at 5:16:56 PM | Inserting Fittings on 3d Views
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
Dont try it in 3d, even if you get it to associate to the pipe it will probably not be in the place you thought it should be, open your plan view and place it there.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Duct Fittings showing halftone
Thu, Aug 11, 2022 at 1:49:20 AM
exporting revit to cad issue- duct and pipe fittings converted as blocks
Wed, Jun 17, 2015 at 1:58:55 PM
Inserting Views on a sheet
Fri, Feb 26, 2010 at 3:18:37 PM
TROUBLE INSERTING VIEWS
Thu, Jan 10, 2008 at 11:03:02 AM
Pipe Fittings move during Synchronize
Wed, May 9, 2012 at 1:32:03 PM
Page generation time: 0.2819
