Forums >> Revit Building >> Technical Support >> Furniture is 'glowing'
Tue, Sep 1, 2009 at 10:10:37 AM | Furniture is 'glowing'
mickc55
3 Stars: 2 Votes
Hi guys,
Got a general question about furniture. It seems like when I perform a render, 1 my imported 3d cad files illuminated or gives of a glow that affects walls, ceilings and other furniture close by.
Pic attached.
Checked that Illuminocity is 0, Got no idea.
Michael.
In Revit We Trust!
Be brilliant,
Michael
Tue, Sep 1, 2009 at 10:30:59 AM | Furniture is 'glowing'
4 Stars: 205 Votes
Check the material properties you have in that furniture...
Tue, Sep 1, 2009 at 1:22:48 PM | Furniture is 'glowing'
tim123
4 Stars: 19 Votes
They're not glowing, they're reflecting.  The lighting levels that you have are quite high.  The attached image shows a render with very bright lights to illustrate the effect on the ceiling of different colour floors, but the same effect can be noticed with lower lighting levels.  This happens in real life also where lights shining on an object will change the colour of surrounding surfaces.
Thu, Sep 3, 2009 at 12:46:59 PM | Furniture is 'glowing'
mickc55
3 Stars: 2 Votes
Yeah this makes sense as I just added a light into the lamp and everything jus got brighter.
Thanks for the responses guys, not back til monday, il post the results!
Michael.
Be brilliant,
Michael
Mon, Sep 7, 2009 at 2:38:54 AM | Furniture is 'glowing'
mickc55
3 Stars: 2 Votes
Tim,
Thank you for the help, it was spot on!
Kindly,
Michael
Be brilliant,
Michael
Extending Furniture
Sun, Oct 23, 2005 at 6:59:43 PM
Some furniture won't display
Wed, Jul 12, 2006 at 5:39:40 PM
Need some patio furniture, grill
Thu, Dec 15, 2005 at 11:46:47 AM
Turning off Certain Furniture
Tue, Jun 20, 2006 at 2:09:52 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Page generation time: 0.2501
