Forums >> Revit Building >> Technical Support >> pendant light ghosts out
Tue, Sep 1, 2009 at 9:51:40 AM | pendant light ghosts out
SteveB
3.5 Stars: 5 Votes
why does a the family of standard pendant lights ghost out?  the family inserts into the drawing but is only invisble in "shading with edges" view display, attachment shows it with SD display and red when it is selected. In ordinary plan view it dissappears.  "lighting fixutures" is set to display in the view.
Tue, Sep 1, 2009 at 10:41:47 AM | pendant light ghosts out
4 Stars: 205 Votes
Steve, did you check the family? the visibility parameters? can you put here that family so I can take a look???
Tue, Sep 1, 2009 at 10:52:28 AM | pendant light ghosts out
SteveB
3.5 Stars: 5 Votes
its the stock pendant fixture that comes with v2009.  It is set to "visible".  ee attached.
Tue, Sep 1, 2009 at 11:21:52 AM | pendant light ghosts out
4 Stars: 205 Votes
Steve, sorry but i can't get the problem, your images is in "Ceiling Plan view" or what???
Tue, Sep 1, 2009 at 12:12:56 PM | pendant light ghosts out
SteveB
3.5 Stars: 5 Votes
i notice that if i manually pick it and, using overide graphics in view/patter/(change to) LINEWEIGHT=2, COLOR=BLOACK PATTERN=SOLID that it now displays.
Tue, Sep 1, 2009 at 4:53:16 PM | pendant light ghosts out
SteveB
3.5 Stars: 5 Votes
Yes, ceiling view
Sun, Sep 6, 2009 at 6:49:29 AM | pendant light ghosts out
SteveB
3.5 Stars: 5 Votes
I figured it out.  Ceiling plan view ranges need to re reset or else you don't see the fixure.
top:  3' (best I can tell this is sort of your eye level from which the plan looks up)
bottom 1' (this seems to be the level at which the plan is cut, must be below "top"Winking
view depth:  11' or whatever ceiling height is.  (view depth is upside down from a plan view. it is how far UP you look. Winking
Sun, Sep 6, 2009 at 7:05:59 AM | pendant light ghosts out
SteveB
3.5 Stars: 5 Votes
One last adustment req'd.  "object styles" / lighting fixtures is set to white... reset to black.
Pendant light placement
Wed, Sep 19, 2007 at 4:03:08 PM
Light Source
Thu, Feb 19, 2009 at 8:01:01 AM
Linear Wall Washer Pendant
Tue, Aug 11, 2015 at 12:21:00 PM
Illuminating Pendant Lights
Tue, Nov 16, 2010 at 2:38:07 PM
Light source inside the light fixture
Fri, Feb 22, 2013 at 7:24:32 AM
Page generation time: 0.0958
