11 Users Online (9 Members):
Forums >> General Discussion >> Revit Project Management >> lineweight problems
Revit 2009 I have attached ground and first floor of building I'm working on, and as you can see lineweight of external wall at ground floor is thicker than line of the same wall at first floor. Anyone knows whay is this happening?
Are you sure it is your wall lines? Do you have a slab edge, site pad or something else in the same position. Tab over the line and see what all you find.
Any chance you've got a foundation wall you're looking at, with a different cut lineweight? Also, things like cove base can muddy up a drawing like that, where there's just not room to print them seperately.
You say you "attached ground and first".... Can you expound on this and maybe look into it further? It almost looks like the plan on the left has a cut plane view through the wall, whereas the one on the right appears that its viewing the top of a wall. Just a thought. Hope it helps....
qab
^_^
Debian + VirtualBox + Revit
Hub, yes it is a wall line, there was no floor or anything else below and I have also tried to copy this wall from ground floor to first floor level but same thing happened, wall line thickness is different. AlterEgo, would it be possible to change cut lineweight of walls on each floor? Qabulin, I meant PDF attachment to my post, sorry. Thanks guys
Lineweight on Surface Patterns? |
Mon, Jun 15, 2009 at 11:54:52 AM
Lineweight in perspecives |
Wed, Sep 18, 2013 at 12:27:42 AM
Lineweight Problem |
Tue, Jan 19, 2016 at 2:26:31 PM
Electrical Fixtures Lineweight |
Tue, Jul 21, 2015 at 12:39:00 PM
Linked Cad - Global Lineweight |
Wed, Sep 2, 2015 at 4:54:03 PM
