14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Printing Issue 2010
69 Posts No Rating |
I am putting one toe into the 2010 water, having read about crash issues. Still using 2009, but a couple of smaller project in 2010 to test if I will have any problem. So far no crash issues. I do have however one issue, I need some help with; In 2009, I 'publish to DWF' In 2010, I can export to DWF. All is normal, but when I open the files in Design Reviewer (latest version) the thumbnails looks fine, but the preview pane is all scrambled and so is the print out. I can print directly to any of our printers, and I am reluctant to go via a DWF Writer when the feature should be built in. Any comments, similar experience or suggestions ? Enjoy
2D & 3D DWFx functionality in 2010 has been working fine for me since beta. What settings are you using?
Regards,
Chris.
Thanks Spot for your attention. The problem comes in ADReview. I am looking at all the settings for xporting to DWF and there are not many option. I set up the printer (default= Revit DWF Exporter). Printer selection just for size of paper/scale/what to include. I try DWF and DWFx. All the same. In ADR, thumbnails are as expected, but preview is scrambled as the print will be. I can print normally directly to any of our printers from Revit In 2009 all is fine. I can not update till I have solved this problem
Revit 2010 Printing Problems [ 1 2 ] |
Wed, Jun 24, 2009 at 11:21:31 AM
16
Revit 2010 printing random lines |
Mon, Jan 4, 2010 at 10:51:09 AM
Printing changes annotations on sheets |
Thu, Sep 15, 2016 at 6:55:41 AM
Printing issue |
Wed, Jul 12, 2006 at 1:12:21 AM
Scope boxes printing, set not to print. |
Tue, Feb 15, 2011 at 6:39:49 PM
