12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Revit 2010 Memory reaching critical limit
22 Posts No Rating |
Hi all, Im having trouble with my 2010 version of Revit. I am recieving a message from revit informaing me that my memory is reaching its critical limit. Twice a day Revit will close unexpectedly without a recovery save option. Direct 3D is turned off and I am not running any other programs. Does anyone know how to fix this problem?? Thanks, Matt
What is ur's system configuration?
Now on the implementation stage.... |
windows xp core 2 duo processor 2.66GHz 4GB RAM GeForce 8600 GT video card
...graphics card
How large are the files you are working on? Do you have a lot of views open? If you are running 32bit windows then you technically only 3GB of RAM. Which isn't a lot for larger files. If you files are over or around 100MB 8GB is recommend and 64bit OS to make use of it of course... I also assume you have correctly set your page file to be twice your physical RAM amount?
Regards,
Chris.
The file im working on is around 50MB Most of the time i do have a number of windows open since i usually don't close i just select a new view form the browser so they would all sit there in the background. my page file is set to maximum 4096 i think thats the right figure isn't it?
and yes my operating system is only 32 bit.
I would suggest having no more than 3 or 4 views open simultaneously... That should help your issue. For every view you have open Revit has to constantly update the graphics every time you add or change something. The less views the less it has to do. 50MB should be fine with 3GB of RAM and 4Gb swap file.
Regards,
Chris.
Thanks mate, ill try to put that into practise
2010- how to removed/hide windows... |
Sun, May 9, 2010 at 7:29:06 AM
Memory spiked... |
Wed, Sep 19, 2012 at 10:06:24 AM
I have enough memory but Revit doesn't agree about that |
Sun, May 10, 2015 at 10:59:23 PM
2009 memory requirements |
Thu, Jul 10, 2008 at 4:08:14 PM
Memory Hog |
Fri, Jul 27, 2007 at 3:58:49 AM
