Forums >> Revit Building >> Technical Support >> Leader origin for multi-line keynote text
Mon, Aug 31, 2009 at 4:27:09 PM | Leader origin for multi-line keynote text
kirchmer
Hi, I am trying to create keynote that has a leader origin in the upper right, whenever the text is long enough to be multiline the leader origin moves to the center of the body of text. I have created a new keynote that has rps that define its origin but that doesn't help, any suggestions?
Thu, Jul 5, 2012 at 9:43:50 AM | Leader origin for multi-line keynote text
FWelliot
I know its been 5 yrs, but maybe this will help those who search the threads for answers.  I had a similar problem as the above mentioned.  I found a work around that worked for me.  I created a filled region with invisable lines and that was transparent that altered the center of the tag to force the leader to originate from the desired point.  Baiscally there is a large box around the tag that makes the center align with the desired point of the tag.  Hope this helps.
Multi-Category Tag with horizontal leader lines - RAC 2012
Wed, Feb 15, 2012 at 4:29:14 PM
Leader Line Line weights
Sat, Feb 7, 2009 at 10:47:57 AM
keynote tag, crooked leader
Tue, Mar 31, 2009 at 4:44:35 PM
keynote text and leader alignment
Thu, Aug 19, 2010 at 8:56:10 AM
Distance from leader to text... Revit 2010
Tue, Jun 1, 2010 at 9:13:51 AM
Page generation time: 0.9144
