Forums >> Revit Building >> Technical Support >> Solid Wood Door in Curtain Wall ?
Mon, Aug 31, 2009 at 4:13:43 PM | Solid Wood Door in Curtain Wall ?
kingkong
I have an interior curtain wall system with a solid wood door.  All the curtain wall doors I'm finding have glass.  What's my best route with this?  Can I somehow convert the "single-flush-no trim" family to a curtain wall panel?
Thanks!
revit architecture 2009.
Mon, Aug 31, 2009 at 4:32:31 PM | Solid Wood Door in Curtain Wall ?
Curtain wall doors work with curtain walls - don't use regular doors.  Start with your glass curtainwall door and edit it creating a new wood curtainwall door.
Mon, Aug 31, 2009 at 4:35:32 PM | Solid Wood Door in Curtain Wall ?
tim123
4 Stars: 19 Votes
You need to make a curtain wall panel that is a door.  You can't convert the wall hosted doors into a curtain wall panel.  You can insert a wall into a curtain wall panel and host a normal door into that and align the grid lines with the edge of the door so that you don't see any of the actual wall that is hosting the door.
Mon, Aug 31, 2009 at 4:38:07 PM | Solid Wood Door in Curtain Wall ?
kingkong
On I go to make a "Wood Door" curtain wall panel.  Thanks!
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
Curtain Wall Panel to Curtain Wall Door
curtain wall door
Tue, Jan 31, 2006 at 1:36:58 AM
Curtain wall with Wood Slats
Wed, Apr 13, 2011 at 10:32:53 PM
Curtain wall door frame
Mon, Mar 2, 2015 at 11:37:33 AM
Page generation time: 1.2390
