21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Sloping Steel Column
97 Posts No Rating |
Is there any way to create sloping steel columns in Revit Architectrue 2010? I've read a lot of posts, and the help (which didn't help) and don't know if this is possible. I have a sloping roof that is supported by steel columns that also slope. I need to be able to place them in plan and slope them to a desired pitch and then attach them to the underside of the roof. Anyone? Anyone? Bueller?
Beams can slope, so make it as a sloping beam instead.
34 Posts No Rating |
Good post, how do you make the top of the column parallel with the ground?
Just cut the beam.
Cut geometry indeed. Thanks.
Sloping Columns |
Tue, Jan 22, 2008 at 1:45:44 PM
Lineweight of steel column in coarse view |
Fri, Jan 7, 2011 at 6:25:48 PM
Aligning top of column to top of beams that are set out by bottom of steel |
Thu, Dec 12, 2013 at 12:35:41 PM
Steel beam to steel/concrete column fixture (Noob question) |
Wed, Feb 27, 2013 at 3:18:10 PM
Concrete pad footing moves with steel column |
Thu, Dec 12, 2013 at 10:58:07 PM
