9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Modifying a footing (revit 2010)
54 Posts No Rating |
So the typical footings that revit allows 24" x 12", 36" x 12", and 36" x18" all use a chamfor from bottom of footing to bottom of slab. Is it possible to modify the typical footing revit uses to something more like the what i have outlined in red on the attached picture? Thanks for the help!
Create a new profile like you want then duplicate the "Type" and change to the profile you just create, when you apply the "Floor Slab edge" in the slab you gonna see what you want....
worked like a charm! Thanks for all the help
Stepped Footing |
Sun, Nov 7, 2010 at 7:35:38 AM
Stepped Footing CADclip Tutorial |
Wed, Feb 10, 2010 at 3:37:09 PM
Continuous Wall Footing ? |
Thu, Aug 23, 2012 at 1:59:47 PM
13
Foundation Top of Footing (when Level is something other than 0'-0") |
Fri, Jan 29, 2016 at 1:40:13 PM
Top of Isolated Column Footing forced to snap to bottom of column |
Mon, Jan 13, 2014 at 7:41:43 PM
