Forums >> Revit Building >> Technical Support >> linked files - material override?
Mon, Aug 31, 2009 at 8:38:08 AM | linked files - material override?
Palazzo
We have a project with linked revit-files. Each contains different buildings.
The masterfile combines all the files to a complete masterplan, and we want to render this plan
Problem is we want to experiment with colours and materials, but all the materials are embedded in the imported models.
Does somebody know a method to override materials in the masterfile? (names of the materials in the linked files are all the same)
Hope you can help......
Mon, Aug 31, 2009 at 9:12:34 AM | linked files - material override?
The project rules!   Find the material names and define them in the project.
Mon, Aug 31, 2009 at 9:59:52 AM | linked files - material override?
Palazzo
The problem is I can't find editable materials used in the linked file.
I can edit linestyles, patterns and others
I used an original materialname in the linked file, find this name in the masterfile, but there's no possibility to edit.
Linked file materials 2016
Thu, Mar 3, 2016 at 3:43:15 PM
Linked file - Cannot remove halftoning [ 1 2 ]
Tue, Apr 11, 2023 at 6:22:17 AM
17
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
Is it possible to get any Silhouette Edges with linked files - elevation view
Sun, May 22, 2011 at 2:39:44 PM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
Page generation time: 1.5457
