Forums >> Revit Building >> Technical Support >> Room Tag issue
Sun, Aug 30, 2009 at 7:36:52 PM | Room Tag issue
plswenson
I am working on a project that has had rooms switching around in several different places throughout the design process. I have deleted rooms that are no longer existing and this has worked. However, I cannot seem to add another room with area tag to my plan unless it was existing from the beginning of the project. I really need to tag the new rooms in order to finish the documents. Please help if you know anything!! Thank you!
Mon, Aug 31, 2009 at 9:21:14 AM | Room Tag issue
Not sure what you are doing wrong but I assure you it is you and not Revit.  Do you have rooms on?  Do you have room tags on?  Are you in a floor level view?
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Room Tag Leaders
Thu, Oct 21, 2021 at 9:45:56 AM
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:40 AM
Room Tag Issue
Mon, Dec 15, 2008 at 10:47:33 PM
Page generation time: 0.6550
