Forums >> General Discussion >> Wishlist >> Select all instances by view
Fri, Aug 28, 2009 at 6:04:20 PM | Select all instances by view
missgayley
missgayley Avatar
*sigh*
I know there's a filter, and I do use it.   But sometimes I need to just select all the 2x6 joists on a particular level to change them to 4x6 joists without changing the 2x4 joists also.
unless I am completely missing something (and please tell me if I am!!) filtering only filters it down to a Structural Framing (Joists) option, which still leaves me with every size of framing that is defined as a joist.
Select all instances by view.... it would be sweet.
Thu, Sep 3, 2009 at 8:39:18 AM | Select all instances by view
JRMello
I completely agree. Sometimes it makes so much more sense to select all instances in particular views. Really bugs me that you can't do it easily.
Thu, Sep 3, 2009 at 9:11:01 AM | Select all instances by view
Ah ... but you can with a couple of steps.  Select all instances ... then isolate elements... then window the view and you have them all in that view only.
Thu, Sep 3, 2009 at 9:21:09 AM | Select all instances by view
JRMello
Good advice. That works, but there's something to be said for the convenience of something taking only one step. And it seems to me that a "Select All Instances In View" command would not be too difficult to create when "Select All Instances" already exisits.
Thu, Sep 3, 2009 at 11:07:04 AM | Select all instances by view
missgayley
missgayley Avatar
WW, i agree,  that is one way....
 however, sometimes you still want to see what's around  ~ or maybe i just like to be difficult ~ J
Thu, Apr 1, 2010 at 7:03:45 PM | Select all instances by view
Luigiman
This will be available on the 2011 Release...
Mon, Apr 26, 2010 at 7:11:08 PM | Select all instances by view
missgayley
missgayley Avatar
this makes me very happy  Smile   (smiley intended!)
Edited on: Mon, Apr 26, 2010 at 7:12:15 PM
Find objects in views using "Select All Instances in View"
Tue, Sep 3, 2024 at 5:10:21 AM
select all instances??
Fri, Feb 6, 2009 at 7:36:04 AM
Select All Instances does not actually show all instances
Thu, Mar 28, 2013 at 1:38:37 PM
Select all of one linetype in a view?
Tue, Jan 10, 2012 at 3:31:14 PM
SELECT ALL INSTANCES
Fri, Jun 6, 2008 at 10:54:52 AM
Page generation time: 2.1220
