Forums >> Revit Building >> Technical Support >> Underlay Override
Fri, Aug 28, 2009 at 11:11:46 AM | Underlay Override
Casparos
Hi all,
is there a way to give the underlay an override, for example, everything under the floor i would like to have it hiddenline type instead of continues  ?
How to ovveride?
Cee
Fri, Aug 28, 2009 at 10:53:42 PM | Underlay Override
qabulin
qabulin Avatar
On version 2010, you can go the Manage Tab >> Settings >> Halftone/Underlay.  Here you can udjust it all you like, but consider that this is a global setting.
In 2009, I think that it should just be under Tools, but someone else will have to confirm.... but you can always consult the help files.
qab
^_^
Debian + VirtualBox + Revit
Fri, Aug 28, 2009 at 11:21:48 PM | Underlay Override
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Right click i.e. one of the wall under the floor-->Override Graphics in View-->By Category..., select Walls-->Projection/Surface-->Lines and override the line with the pattern you want....i think qabulin needs a rest....ShinyShinyShiny.....
Fri, Aug 28, 2009 at 11:37:33 PM | Underlay Override
qabulin
qabulin Avatar
you say potato, i say potatomorts... WHATEVER! >_<
it works boths ways...
Stop chasing my replies and "peep" my threads in studio! Puh
qab
^_^
Thu, Sep 3, 2009 at 9:48:16 AM | Underlay Override
Casparos
Qubulin,
 I Need it as an global override and dont want to override by category, but indeed both do work!
Thanxs
Underlay
Thu, Oct 11, 2012 at 8:15:33 AM
Underlay is not working
Mon, Apr 28, 2014 at 5:29:50 PM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
misguided underlay
Tue, Feb 19, 2013 at 8:14:29 AM
wrong underlay showing
Mon, Jan 27, 2014 at 1:29:57 PM
Page generation time: 1.1501
