Forums >> Revit Building >> Technical Support >> Thickened floor slab to support a wall but no on edge of the floor
Fri, Aug 28, 2009 at 8:34:00 AM | Thickened floor slab to support a wall but no on edge of the floor
Casparos
Hi all,
looking for a 3d parametric : Thickened floor slab to support a wall but no on edge of the floor
Anyone?
Fri, Aug 28, 2009 at 9:05:20 AM | Thickened floor slab to support a wall but no on edge of the floor
Your question is not clear.  You can use floor edge sweeps for thickened floor edges.  Or do you want a seperate wall footing?
Fri, Aug 28, 2009 at 11:18:03 AM | Thickened floor slab to support a wall but no on edge of the floor
Casparos
Yes,
its a footing underneath a floor that is not on a floor-edge, but the footing is as long a the wall!
Is it clear, like attached image but then fully paramtric in 3D,
Cee
 it tried it to create a wall profile, but it is underneath the base constraint so doesn,t allow me to create the slab. and an reinforced rib for the floor doesn't seem possible.
Fri, Aug 28, 2009 at 11:39:57 AM | Thickened floor slab to support a wall but no on edge of the floor
Ok... you mean an interior thickened slab.  You could do this as an inplace family - category floor - as a sweep and join it with your floor.
Thu, Sep 3, 2009 at 10:07:12 AM | Thickened floor slab to support a wall but no on edge of the floor
Casparos
Thanxs!
Thickened Slab Not Cutting Floor Line Out
Wed, Dec 28, 2011 at 7:54:13 AM
floor slab edge
Fri, Aug 22, 2008 at 3:31:34 AM
2 Thickened Slab Edges in ONE Foundation Slab
Mon, Jun 6, 2011 at 12:13:35 PM
Creating slab edge...
Tue, Nov 4, 2008 at 3:36:02 PM
Trapezoid shaped Wall-Foundation or floor slab-edge!! [extra reinforced rib]
Wed, Feb 6, 2019 at 7:54:58 AM
Page generation time: 0.7901
