Forums >> Revit Structure >> Technical Support >> Slab Thickness Tag
Fri, Aug 28, 2009 at 7:02:09 AM | Slab Thickness Tag
bradstc
New to revit and trying to tag my slabs.  We usually place a hexagon and nominate slab thickness and setdown for each different slab component.  I haven't found any tags that will allow me to do this.  Can anyone tell me if we can do this out of box or how to build a tag to do this please?
Fri, Aug 28, 2009 at 7:16:44 AM | Slab Thickness Tag
You can not create a tag in Revit that reads a thickness.  That is true for all elements.  But it can read a type parameter that you set.  The stock architectural tag reads the "Type name"  So you could place your value there or change your tag to read a differnt parameter (s) .
tagging slab level and thickness?
Thu, Jun 4, 2009 at 6:58:43 PM
Slab tag positioning
Thu, May 14, 2015 at 8:43:38 AM
slab schedule
Mon, Apr 19, 2010 at 9:10:27 AM
Wall line thickness
Mon, Sep 26, 2005 at 5:47:35 PM
Suspended Slab problem
Thu, Aug 19, 2010 at 3:15:32 AM
Page generation time: 0.2137
