Forums >> General Discussion >> Revit Project Management >> How 2 convert more number of Revit (*.rvt) to AutoCAD(*.dwg) files @ a time
Fri, Aug 28, 2009 at 5:33:08 AM | How 2 convert more number of Revit (*.rvt) to AutoCAD(*.dwg) files @ a time
prashi
Hello,    I know we can convert Revit (*.rvt) file to AutoCAD (*.dwg) file  one at a time, Like i havementioned belowFile > Export > CAD Formatsa dialog box pops up where we can select place to save the CAD file in required format..i.e., in save as option, i was selecting *.dwg & i use to select wire frame.      Since i have to convert more number of files, I wanted to know is there any other options,software or scripts available to convert more numbers of  Revit (*.rvt) files to AutoCAD (*.dwg)files at a time. Could anyone can help me in this regard.Any help is appreciatedThanking YouPrashanth
Fri, Aug 28, 2009 at 6:40:58 AM | How 2 convert more number of Revit (*.rvt) to AutoCAD(*.dwg) files @ a time
You are using the term "convert file" and there is no such thing.  You can export single or multiple views and or sheets from one Revit project. When you start the process, you are given the choice of current (view/sheet) or select multiples from your project.
Need to convert RVT file to RFA
Sat, May 22, 2021 at 6:14:06 PM
Some problems with the export from rvt to dwg
Thu, Jan 14, 2010 at 3:10:42 AM
Exporting Revit 2009 (.rvt) to AutoCAD (.dwg)
Mon, Jul 13, 2009 at 3:55:27 PM
Revit file export to autocad?
Tue, Aug 4, 2009 at 4:46:16 AM
2D DWG Convert to 2D Revit
Mon, Nov 23, 2015 at 1:57:38 PM
Page generation time: 2.0626
