Forums >> Revit Building >> Technical Support >> A odd problem of opening files... ???
Thu, Aug 27, 2009 at 8:23:57 PM | A odd problem of opening files... ???
a1142730
I have a really odd problem with Revit2010 recently. It never happened before. I am documenting a small residential project at the moment. Every morning I turn on my computer to open the file. Revit just gets stuck on the half way of opening file. The progress bar at the bottom stops at exact 50%. If I click on the program, it just says no responding. and I have to close it and restart the computer. Then everything seems going back to normal. Is there anyone facing something like this before? Any clue please...???
PS:  my computer is the best in my office. It is Duo 3.0/4G/Nv GeForce GTS 250 1G/32 bits
Fri, Aug 28, 2009 at 6:49:25 AM | A odd problem of opening files... ???
You are filling something - registry, temp files or ? at the system level and the re-start clears that.  We run cc-cleaner and re-boot our systems on a regular basis.  Seems that the number of images you use in revit or view on the internet affects this so I think it is a temp file issue.
Mon, Aug 31, 2009 at 12:58:31 AM | A odd problem of opening files... ???
a1142730
Hi WWHub, thanks for the reply. I think it is caused by temp files. I cleaned up C drive this morning. It seems ok now...
Revit 2009 problem opening large files
Wed, Apr 23, 2008 at 9:36:38 PM
Odd problem when linking files
Thu, Apr 3, 2008 at 11:18:12 AM
Faster opening of files
Fri, Dec 9, 2011 at 7:21:22 AM
Cant see stairs in opening in plan view
Wed, Nov 26, 2014 at 10:35:34 AM
Odd error message
Wed, Jul 11, 2007 at 9:51:49 AM
Page generation time: 1.4877
