Forums >> Revit Building >> Technical Support >> alt keycodes not working in 2010
Thu, Aug 27, 2009 at 1:35:34 PM | alt keycodes not working in 2010
icedreamer4life
I am new to Revit Architecture 2010. I was always able to use the windows Alt keycodes in my text boxes. Now in any project that is in 2010, I am getting really strange chinese symbols or box symbols instead of the degree and diameter symbols?? Anyone have any reasoning to this??
Thu, Aug 27, 2009 at 1:43:16 PM | alt keycodes not working in 2010
4 Stars: 205 Votes
Did you check the "Font"?
Thu, Aug 27, 2009 at 1:44:14 PM | alt keycodes not working in 2010
icedreamer4life
yes, and all looks to be the same as used in 2009?
Thu, Aug 27, 2009 at 1:45:29 PM | alt keycodes not working in 2010
4 Stars: 205 Votes
What is the font you are using in 2009? also in 2010?
Thu, Aug 27, 2009 at 1:48:47 PM | alt keycodes not working in 2010
icedreamer4life
'Arial' for both.
Thu, Aug 27, 2009 at 1:55:27 PM | alt keycodes not working in 2010
4 Stars: 205 Votes
Wierd, are you sure? because that's the font i just test in the both (2009/2010) and it work fine, same characters...
Thu, Aug 27, 2009 at 1:57:29 PM | alt keycodes not working in 2010
icedreamer4life
Yea, I'm sure we've never used any other font?? I even checked using the keycodes thru other programs, just in case it was my computer, but they all worked fine too? Things like this are so frustrating?
Thu, Aug 27, 2009 at 2:04:04 PM | alt keycodes not working in 2010
tim123
4 Stars: 19 Votes
I found that happening also, but after starting Revit again it worked fine.
Thu, Aug 27, 2009 at 2:10:09 PM | alt keycodes not working in 2010
4 Stars: 205 Votes
I just tried with other font and works fine ICE...
Tue, Sep 8, 2009 at 1:01:37 PM | alt keycodes not working in 2010
icedreamer4life
tim123 - Weird? It did work after re-starting Revit? Thanks for the help!
Tue, Sep 8, 2009 at 3:40:56 PM | alt keycodes not working in 2010
#11
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is a known bug, ensure you have the latest update installed.
Regards,
Chris.
alt codes
Sat, Jul 11, 2009 at 11:26:39 AM
Shortcuts for symbols
Sat, Jul 7, 2007 at 3:16:10 PM
The "Alt" key
Mon, Sep 21, 2009 at 5:25:25 AM
Text Symbol Hot keys (ALT+......)
Tue, Jul 6, 2010 at 11:59:49 AM
Superscript/subscript/degree text symbols in Revit
Mon, May 9, 2005 at 6:08:59 PM
Page generation time: 0.5177
