Forums >> Revit Building >> Technical Support >> View alignment on Multiple Sheets
Thu, Aug 27, 2009 at 1:25:15 PM | View alignment on Multiple Sheets
hunterfloyd
It seems that there is now precise way to lock views on a sheet into the same location on different sheets.  For example multiple levels of a floor plan on separate sheets.  I've seen multiple posts on this subject, but was wondering if this is possible in Revit 2009?  Thanks for your time.
HuntFlo
Thu, Aug 27, 2009 at 2:12:19 PM | View alignment on Multiple Sheets
tim123
4 Stars: 19 Votes
You can't snap on viewports, so you cant do it exactly.  You can draw some lining up marks in the sheet family and give them a visibility parameter that you can switch off after aligning the viewports.  It won't be exact, but if you zoom in close you can place them quite accurately.
Same View on Multiple Sheets
Sun, Aug 28, 2005 at 5:51:36 PM
Want to have typical washroom elevation on multiple sheets
Fri, Oct 23, 2015 at 11:20:00 AM
Multiple sheets from same floor plan view with different scales?
Fri, Aug 1, 2008 at 12:01:43 PM
Engineering Stamps on Multiple Sheets
Wed, Apr 8, 2015 at 11:13:44 AM
Drafting Views on Multiple Sheets-Revit 2008
Wed, Sep 3, 2008 at 3:11:48 PM
Page generation time: 0.6623
