19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Stacking differant wall types?
54 Posts No Rating |
If I wanted a wall that started with CMU up to 4'-0" high, then built a stud wall on top of that 10'-0" (total wall height of 14'), how would I go about making that in revit? Also, if I have a stucco wall and want to put a control joint in at 4'-0" high and change the stucco color between the top and bottom, even though its apart of the same wall, how do I make that happen? Any help is very much appreciated. Thanks!
Use the "Stacked walls", check the HELP menu....
With regard to making the wall different colours you can use the Split Face tool, under Modify and then use the paint tool to paint the wall different colours.
Wall Sweeps |
Sun, Jul 12, 2009 at 1:54:07 PM
13
New Revit User with stacking wall question |
Mon, Jun 11, 2007 at 10:02:55 PM
Halfwall w/ countertop |
Fri, Nov 11, 2005 at 4:33:28 PM
How do I make custom wall types publicly accessible? |
Sun, Apr 4, 2010 at 2:17:08 PM
Revit 2009 : Area Separation and Mass Room Stacking and Blocking |
Mon, Nov 24, 2008 at 4:23:24 PM
