Forums >> Revit Building >> Tips & Tricks >> Revit 2010 rendering & sky options
Thu, Aug 27, 2009 at 11:41:06 AM | Revit 2010 rendering & sky options
bazar
bazar Avatar
I was wondering if there is a way to change the sky in a rendering. I know revit uses the presets that come with it, but how do you go about changing or adding to these? Any help would be great.
Thu, Aug 27, 2009 at 12:43:13 PM | Revit 2010 rendering & sky options
4 Stars: 205 Votes
Export the render in PNG file, then create a drafting view and import the render (PNG) and the sky you want.....
Thu, Aug 27, 2009 at 8:48:41 PM | Revit 2010 rendering & sky options
erland73
erland73 Avatar
4.5 Stars: 85 Votes
For a best reference to what Typhoon says, watch this video: Revit 2009-->Miscellaneous-->4. Rendering with Background Images....  http://www.cadclips.com/FreeCADclips.htm
Fri, Aug 28, 2009 at 7:24:42 AM | Revit 2010 rendering & sky options
bazar
bazar Avatar
thanks erland73, that was perfect. It's similar to taking the rendering into photoshop, but much easier and quicker.
I'm still wondering how you can change the sky that is being used in the rendering processes. If you look at "Autodesk Revit Architecture 2010\Data\Rendering\assetlibrary_base.fbm\Environments\SunAndSky" you'll see the sky images that are being used. What is the method for changing or adding to these.
Thu, Oct 1, 2009 at 5:54:58 PM | Revit 2010 rendering & sky options
nevaeh104
I would like to reiterate bazar's question. I noticed the same thing; that there are other sky images in the asset library. However whenever I render (I usually try to choose Sky: Few Clouds), the background is so dull! How do I get it to not be so boring? Attached is an example of what I mean. The sky is just so dull and lifeless. Help!
Wed, Oct 5, 2011 at 9:40:58 AM | Revit 2010 rendering & sky options
juniorborgesat
Same question here... I've noticed this library as well and couldn't figure out how to use those sky samples.
Thu, Dec 8, 2011 at 1:08:33 PM | Revit 2010 rendering & sky options
rambo6
4 Stars: 4 Votes
when you click sky. go down to image and load an image in from your computer. like this one. this is in 2012. I have used 2010, but I dont remember if this is an option or not
Trouble with sky for rendering
Wed, Jul 21, 2010 at 9:10:26 AM
Rendering Questions re Sky
Tue, Sep 19, 2006 at 4:34:00 PM
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
Rendering without a sky (alpha transparent) (2010)
Fri, Sep 18, 2009 at 9:45:49 AM
Need Rendering help in revit 2012
Sun, May 27, 2012 at 11:41:22 AM
Page generation time: 3.8772
