Forums >> Revit Building >> Technical Support >> how I print 2 or more sheets in the same print sheet?
Thu, Aug 27, 2009 at 5:54:58 AM | how I print 2 or more sheets in the same print sheet?
querosaber
how i print 2 or more sheets in the same paper sheet . for example i have to shhets revit and i want to print togheter? how i do?
Fri, Aug 28, 2009 at 9:12:18 AM | how I print 2 or more sheets in the same print sheet?
jhayden
jhayden Avatar
I don't quite understand the question. Are you trying to print multiple sheets at once?
Mon, Aug 31, 2009 at 4:18:43 AM | how I print 2 or more sheets in the same print sheet?
querosaber
imagine you have a printer with A0 papper and have a sheet in A4 size in revit to print . its a wastage of papper. what i do with autocad is print a few sheets at same time . in revit i can copy the shhet with viewport.
how you do?
Mon, Aug 31, 2009 at 9:15:10 AM | how I print 2 or more sheets in the same print sheet?
You can't from Revit ... You will have to combine them outside of Revit - maybe using PDF ?
Mon, Aug 31, 2009 at 9:36:48 AM | how I print 2 or more sheets in the same print sheet?
jhayden
jhayden Avatar
When I have multiple sheets to print, I go into the print dialogue box and select 'Selected views/sheets'-> 'Select' and choose the sheets or views I want to print. Then I go into 'Setup', choose the paper size and Source. The source is dependant on what size of sheet I'm printing. Our plotter has 2 rolls, a 36" and a 30" roll, so I choose my roll according to the size of paper.
I hope this answers your question.
Jeff H
Sheets missing when I go to print
Wed, May 20, 2015 at 9:36:38 PM
13
Print to PDF sheets with DWG files on them help. Maybe Bluebeam help
Mon, Oct 26, 2015 at 10:55:35 AM
PRINT RANGE SETS BY PARAMETERS
Wed, Feb 23, 2011 at 12:56:06 PM
Print Order
Wed, Nov 21, 2012 at 2:17:41 PM
Print to 3 printers
Mon, Apr 26, 2010 at 8:55:05 AM
Page generation time: 0.3076
