Forums >> Revit Building >> Technical Support >> Room finish Schedule showing Deleted Rooms
Wed, Aug 26, 2009 at 3:45:27 PM | Room finish Schedule showing Deleted Rooms
farva
I have created a room finish schedule, it updates whenever I add a room, and schedules all of the information correctly. However when I delete a room from the model, the room and all of its' parameter values remain in the schedule. Any thoughts?
Wed, Aug 26, 2009 at 3:56:37 PM | Room finish Schedule showing Deleted Rooms
Read your HELP - It tells you that happens - you have to delete from the schedule... this changed with 2009 ... some ACAD programmer must have done it... Not smart!
Renumbering rooms -- rooms out of numeric order on Room Finish Schedule
Thu, Dec 10, 2015 at 11:01:57 AM
Rooms not showing up in room schedule, please help
Sat, Oct 27, 2012 at 10:52:34 AM
Fri, Jan 18, 2008 at 2:36:53 PM
Can't generate the room finish schedule
Fri, Jun 15, 2007 at 3:30:58 PM
Room Schedule - Multiple Room References
Sat, Dec 5, 2009 at 4:34:02 PM
Page generation time: 0.9595
