22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Removing unwanted parameters from families
4 Posts No Rating |
I need to remove the default parameters from the room family. I.E. Wall Finish, Base Finish. I have already created shared parameters for these items that I can schedule and that fit my needs better than the out of the box parameters. My concern is people will get confused when they go into the room properties and see parameters that are similar and will not know which one shows up in the schedule. Any suggestions?
Rooms are system families and you are stuck with what is in there. It may have been better if you could have found away to use those. I don't know why those would not have worked for you.
4 Posts No Rating |
One reason they dont work for my purposes is we designate walls by cardinal directions. The default parameter only offers a singular wall finish, this supposes that all walls in every room have the same finish, which is rarely the case.
You really shouldn't have a problem if you use room types and or fill in your schedule from the schedule. If your users are accostomed to a cardinal schedule, I don't think anyone will get confused with Wall Finish vs North Wall Finish - etc.... and even if they do - that data will not be in your schedule - perhaps you should default these unwanted items to DO NOT USE. We have not found the cardinal process very effective. We use paint...etc for the wall finish then use finish tags in the plan or on elevations - works better for us.
Edited on: Wed, Aug 26, 2009 at 3:30:18 PM
3 Posts No Rating |
It seems that you can't remove the default family parameters, but you can remove ones you have made that are no longer needed.
In the Family Editor (this is in version 2012), use Home > Properties > Family Types to list the current parameters in the family. CLick on the one you want to get rid of, and click on Remove.
Door family - how to delete unwanted parameters |
Tue, Feb 7, 2006 at 3:25:01 AM
Parameter management |
Thu, Mar 13, 2014 at 11:16:42 AM
Instance Parameters in titleblock not linking |
Wed, Dec 28, 2011 at 10:31:23 AM
12
removing familes |
Thu, Jan 30, 2014 at 1:30:28 PM
Array removing existing parameters |
Sun, Feb 22, 2009 at 7:46:43 AM
