Forums >> Revit Building >> Technical Support >> Scheduling/Quantities copy and paste???
Wed, Aug 26, 2009 at 10:00:48 AM | Scheduling/Quantities copy and paste???
eightangrybears
I am working on getting a quantity together for my building of the amount of ductwork (mostly the area of sheet metal needed). I made the duct schedule and got the area in there and EVEN asked it to calculate the totals so that we can have a total...Unfortunately, it doesn't show up and I can't copy and paste any part of the table into Excel to try and do it myself. PLEASE, someone tell me I don't have to go one by one and put them in by hand!!!
Wed, Aug 26, 2009 at 10:05:09 AM | Scheduling/Quantities copy and paste???
Find the schedule in your browser and open it for editing... click file/export/schedule.   This will give you a tab delimited txt file that you can open in excel.
Wed, Aug 26, 2009 at 10:14:42 AM | Scheduling/Quantities copy and paste???
eightangrybears
I'm using MEP 2010 so I can't do a file/export unless I should save it as it's own revit file first? I have the option to save as a new file but only an rvt file, not a text or anything else...Maybe that's what you meant?
Wed, Aug 26, 2009 at 10:26:31 AM | Scheduling/Quantities copy and paste???
eightangrybears
I guess through the help function it said I should go to my schedule view, which I would assume is just the one that shows the schedule, then click the R button and go to export>reports>schedule BUT it only lets me pick room and area with the SCHEDULE part greyed out so I can't pick it...any advice?
Wed, Aug 26, 2009 at 10:30:09 AM | Scheduling/Quantities copy and paste???
eightangrybears
Maybe I should just search the help functions more often...I figured it out but thanks for the help WWHub
Wed, Aug 26, 2009 at 10:30:40 AM | Scheduling/Quantities copy and paste???
I don't understand.  You say you are in MEP.  Then why would you have to save as a REVIT file?  ... It is one already!
I don't have MEP but I believe the process is the same ... follow what I told you to do. It works - I use it all the time.
Wed, Aug 26, 2009 at 10:40:53 AM | Scheduling/Quantities copy and paste???
eightangrybears
Well basically the deal was that there is no FILE button to hit. I had to be in the schedule and then actually click on the header (not just anywhere apparently) and then hit the big R button in the top left then click export, report, schedule which automatically saved it as a delimited text file. There is an option to save the report/schedule as its OWN rvt file if you right click the schedule in the project browser, but that just made no sense because it didn't link any of the information, it just brought in the headers basically. Thanks for the help, though...
Wed, Aug 26, 2009 at 10:44:38 AM | Scheduling/Quantities copy and paste???
Sorry ... I'm in 2009 and you didn't say you were in 2010.  You should always say what platform you are on in your posts.
Oops .. yo did say in your second post and I missed that - sorry.
Edited on: Wed, Aug 26, 2009 at 10:45:29 AM
Wed, Aug 26, 2009 at 10:46:26 AM | Scheduling/Quantities copy and paste???
eightangrybears
Yeah...thanks...I should just change my name to MEP 2010 instead of eightangrybears, but then I would still have people asking me...but yeah, I will make sure to do so from now on...thanks again
Edited on: Wed, Aug 26, 2009 at 10:48:08 AM
Copy and Paste
Fri, Mar 6, 2009 at 5:31:33 PM
Copy and Paste Elements from Linked Models is Easy !
Thu, Jul 4, 2019 at 4:23:18 PM
copy and paste
Sun, Dec 18, 2005 at 8:40:14 PM
Copy & Paste into Teamwork file
Tue, Nov 11, 2008 at 8:47:27 AM
copy & paste = crash
Tue, May 15, 2007 at 8:31:14 AM
Page generation time: 0.5092
