Forums >> Revit Building >> Technical Support >> 2010 Ridge tile
Wed, Aug 26, 2009 at 4:27:23 AM | 2010 Ridge tile
nirim
5 Stars: 12 Votes
Hi there Revit city people
Can anybody know why ridge tile on a dormer roof that been attached to the main roof by the ‘Join / un join roof’ do not connect automatically to the main roof as well? And why I can not extend it by dragging the blue dot or by the temporary dimension to connect it to the main roof?   I am working on REVIT 2010 and that problem never append on the advanced version of REVIT 2009.
nirim
Wed, Aug 26, 2009 at 5:56:49 AM | 2010 Ridge tile
4 Stars: 205 Votes
Can you please put some images here so we can take a look to figure what really are you trying to do??
Wed, Aug 26, 2009 at 6:31:55 AM | 2010 Ridge tile
nirim
5 Stars: 12 Votes
Hi there Typhoon
Attached PDF image of the problem, the ridge on the right is how REVIT place the ridge and the one on the left is how it’s supposed to be, I manage to do it bi drag the blue point intuitively because I can’t snap it to anywhere (the blue point).
nirim
Wed, Aug 26, 2009 at 9:27:26 AM | 2010 Ridge tile
4 Stars: 205 Votes
Did you create that "Ridge Tile" family in a "Generic Model LINE based"???
Wed, Aug 26, 2009 at 10:06:02 AM | 2010 Ridge tile
nirim
5 Stars: 12 Votes
No, I use it as I use to do in Revit 2009 i.e. I define new type for roof fascia and instead using fascia board as a profile for the family I change the profile to profile resemble the ridge tile. As I mention earlier, in REVIT 2009 that method work fine.
nirim
Wed, Aug 26, 2009 at 2:17:29 PM | 2010 Ridge tile
4 Stars: 205 Votes
Yeah, must be a "bug", i don't know, it works fine if you create the gable in the main roof with "slope" but when you create the gable by "Extrusion" it don't follow the ridge to the the end....
How to model a Ridge & Hip Tile on the roof?
Thu, May 10, 2007 at 10:23:39 PM
Ridge Tiles
Tue, Jul 19, 2005 at 9:17:54 AM
Ridge Capping?
Fri, Jan 27, 2017 at 6:44:05 AM
Ridge Capping
Thu, Apr 21, 2005 at 6:59:24 AM
rafter to ridge connectionu
Wed, Oct 2, 2013 at 4:37:24 PM
Page generation time: 0.1661
