Forums >> Revit Building >> Technical Support >> Removing/editing single dimension in dimension string
Wed, Aug 26, 2009 at 12:10:27 AM | Removing/editing single dimension in dimension string
rudyard
1 Stars: 1 Votes
I have a dimension string that I wish to alter 1 particular dimension (the 90 in the image).  You see it does not need to be there as it is dimensioned above, I just want the ticks to stay with no text.
I have read when searching about doing the small text trick (I have done that in autocad and works well), however I cannot seem to select the dimension individually......how do I alter just that 1 dim as it seems to act as a whole element?
RAC2009
Cheers.
Wed, Aug 26, 2009 at 12:46:34 AM | Removing/editing single dimension in dimension string
b8dnbbr
maybe this will do that? http://www.integr-8.com/besidethecursor/2009/08/removing-portions-of-continuous.html#links
Wed, Aug 26, 2009 at 1:06:41 AM | Removing/editing single dimension in dimension string
rudyard
1 Stars: 1 Votes
Thanks for the link (and a video to boot!) it almost worked perfectly.  Whilst that is a great tip to know anyway incase I have to delete one, it actually adjusts the next dimension to fill the gap of the deleted dimension i.e. it doesnt just leave a gap in the dimension string, it makes 1 dimension longer to fil the gap.
I even tried a filled and masking region to just block the text in a hack work around but these seem to cut around dimension text, so whilst I could block the dimension lines with filled region, the dim text remained!
Wed, Aug 26, 2009 at 7:12:02 AM | Removing/editing single dimension in dimension string
Sorry but I doubt you can do this.  I don't understand but if you have to have an empty dimension, you could place a string on each side and in this empty one, replace the dimension with a period.
removing dimensions from the dimension string
Mon, Feb 5, 2007 at 6:31:16 PM
Dimension strings not adding up to the total length dimension string (2017)
Fri, Mar 23, 2018 at 1:33:58 AM
Adding a dimension to a dimension string...
Wed, Jul 10, 2013 at 3:42:09 PM
dimension string problem
Thu, Oct 18, 2007 at 1:21:31 AM
Dimension String
Wed, Nov 22, 2006 at 3:05:15 PM
Page generation time: 0.3680
